Posted by Bazyle on 14/02/2023 13:42:00:
I think Biagio has the wheel cutting engine but just not the cutting frame. However that is a very simple item make. Just a U shape cut out of a solid block or by silver soldering some bars. Each arm uses a cap head screw or grub screw with a point ground on the end.
You need several of the small spindles to hold different bore cutters.. The are about 50mm long and have normal centre holes at each end so are turned between centres. First find the nut of large enough diameter to save having to do internal screwcutting.
If you think you need to buy this item you could also research 'ornamental turning ' supplies as they sometimes use similar cutters.
That's correct! my wheel engine is incomplete and I need the cutting frame.
a C shape with a screw on top and bottom and the spindle running between the screw centers:
Something like the below shape that I tried to draw with the keyboard chars..
. _______ |__
. | ________|
. | | __|__
. _______| | ——
.|_______| | ||||
. | |_____|__
. | _________|
I will have a look at the ornamental turning spindles.
Biagio
Edited By Biagio Cerruto on 14/02/2023 14:58:26
Edited By Biagio Cerruto on 14/02/2023 14:58:45
Edited By Biagio Cerruto on 14/02/2023 14:59:04
Edited By Biagio Cerruto on 14/02/2023 14:59:18
Edited By Biagio Cerruto on 14/02/2023 14:59:37
