Done a couple of Indesits and a Creda over the last couple of years.
The Creda had cracked the spider supporting the drum, but had a valve problem too, so was scrapped (kept all the good bits and electronics in good hoarder fashion, much to SWIMBO’s dismay) .
Of the Indesits, one got away with a set of bearings and seals, cost about a tenner all in with postage, and the other had broken the spider, so needed a new spider and hub assembly, cost about £30, both were still good machines so worth doing.
The bearings on them both used rubber shielded types, plus external seals on the bearing housing.
Both of the washers were done and dusted in half a day and back in action again.
If you get the full model number off yours and stick it in the search box on eBay, you’ll probably turn up scores of hits for bearing kits and spiders etc.
Google UK will also spit out loads of mail order suppliers, some of whom cover a wide range of machines, but look for co.uk websites rather than .com though, otherwise American sites will be in overabundance.
Don’t hang about though, otherwise your life will be misery until the job’s either done, or you’ve coughed up for a new machine!
