Posted by SillyOldDuffer on 30/01/2021 12:12:28:
Another mystery my books don't answer is thread angles. Metric and American bolts are both 60°, Whitworth is 55°, Lowenherz 53.1333°, and Thury and BA are 47.5°. Just guessing, but within the range of practical thread angles I think 60° provides the strongest thread, whilst the weaker 47.5° angle provides higher friction and is less likely to come undone. Does anyone know the actual answer?
Wrong way round. The 60degrees thread is the weakest and less likely to un-do. The thread is a double wedge, a small pitch and large thread angle will give a small angle wedge. Hence the use of 60degrees and 26tpi used on cycle threads. It also suggests that BA screws would be frequently undone and done up.
As for washers, generally they have been used under nuts for at least 170 years. Before then washers were difficult to make and not used. There are no washer on the Pontcycslite aqueduct. I worked with jet engines where each set of flanges were held together with 100s of flanged screws and nuts (without washers). I don't think washers were used with larger, ordinary, nuts used in the core of the engine.
As for models, this is simple. If the model is "generic", such as a Stuart 10, use washers. If it is of an actual full size engine etc, copy the full size. If it is your own design you can make the rules (but you should stick to them).
JA
The thread answer suggests that lab technicians would be cack-handed and motorcyclists very careful with spanners.
Edited By JA on 30/01/2021 13:19:15
Edited By JA on 30/01/2021 13:20:05
