Washers under nuts
Washers under nuts
Home Forums Beginners questions Washers under nuts
Viewing 25 posts - 1 through 25 (of 51 total)
  • #523517
    Former Member
      @formermember12892
      Former Member
        @formermember12892
        #523518
        Brian H
          @brianh50089
          I would say yes but it can sometimes be difficult to get the correct scale size for a model unless you make your own.
          #523521
          mechman48
            @mechman48
            Usually yes; unless you use flanged nuts.
            Geo.
            #523522
              Posted by br on 29/01/2021 15:07:06:
              Should washers ALWAYS ? be fitted under nuts ?
              No … Sometimes the nut is captive [in a suitably shaped recess] and the washer is then much more useful under the head of the bolt.
              Anonymous
                No; in the photos I have of full size Burrell SCC traction engines almost none of the nuts have washers underneath them.
                #523526
                gary
                  @gary44937
                  no. but they stop your paint from damage when tightening up.
                  #523528
                  john fletcher 1
                    @johnfletcher1
                    Under which bit rotates, we were told and I've stuck with it. John
                    #523529
                    Russell Eberhardt
                      @russelleberhardt48058
                      There are some circumstances ahere a washer should NOT be used. For example, if both the bolt and the surface it's fitted to are hardened an normal soft washer will reduce the reliability.
                      Russell
                      #523530
                      Emgee
                        @emgee
                        Certainly if material being fixed is likely to be damaged by the nut, damage can be reduced if the hex is turned off at the point of contact but I prefer a washer to spread the load.
                        Emgee
                        #523542
                        not done it yet
                          @notdoneityet
                          Should washers ALWAYS ? be fitted under nuts or not?
                          Simple answer to the OP’s simple question is No.
                          #523545
                          Nicholas Farr
                            @nicholasfarr14254
                            Posted by Russell Eberhardt on 29/01/2021 15:34:42:
                            Russell
                            Hi Russell, but you can get hardened washers.
                            Generally, you don't have to have any washers at all, if you don't want them, but if you are bolting a thin sheet to a thicker section it would be advisable to have a washer in most cases, on top of the thin sheet, whether it's the head of the bolt or the nut. Personally, I like to have them under both head and nut in most situations where it is possible. In structural steelwork it is common to see them on both sides, as the holes are very often bigger, mainly for easy erection and small adjustments.
                            Regards Nick.
                            #523551
                            Tony Wright 1
                              @tonywright1
                              Looks nicer with washers ! But there isn’t any law that says you have to .Sometimes you have to make yourself own decisions. 😊
                              #523589
                              Former Member
                                @formermember12892
                                #523597
                                Anonymous
                                  I'd rather be wrong than wright. smile
                                  #523603
                                  Pat Wright 1
                                    @patwright1
                                    I'd rather be wright than wrong. smile
                                    Pat
                                    #523606
                                    not done it yet
                                      @notdoneityet
                                      Do two Wrights make a Wrong?🙂
                                      #523607
                                      Pat Wright 1
                                        @patwright1
                                        No. Two wright's made 3 more wright's.smile
                                        Pat
                                        #523612
                                        Nicholas Farr
                                          @nicholasfarr14254
                                          Hi, well that should be all wright then! right! or is that wrong also. indecision
                                          Regards Nick.
                                          #523617
                                          Tony Wright 1
                                            @tonywright1
                                            Now stop this, you’re all being very silly !   Name the program ?
                                            Edited By Tony Wright 1 on 29/01/2021 23:27:15
                                            #523660
                                            Mike Hurley
                                              @mikehurley60381
                                              Personally I tend to use washers most of the time for stuff I'm making, just feel they give a better 'fit' to things. If you study the vast majority of early industrial / victorian engineering they never seemed to use them. Was this because of the extra cost or just considered unecessary? When did they start to become in regular use, and was it one of these trends that started perhaps in America and spread over here or vice versa? Have often wondered. Regards
                                              #523663
                                              Mick B1
                                                @mickb1
                                                I'd rather chew up a sacrificial component than a spotface, and I'd rather spread the compressive load there and at the bolt end as well, so my default position is to use them at both ends.
                                                Unless otherwise prompted by other tech considerations, shortage or laziness.
                                                #523668
                                                  Posted by Mike Hurley on 30/01/2021 11:18:36:
                                                  Intrigued by the why washers question I went through my collection of Engineering Books in hope of finding an explanation. Nope! Instead I found inconsistencies. Drawings sometimes show washers and sometimes not. There's a British Standard covering metric washers but it concerns itself only with dimensions. BS metric washer can be made of almost anything ranging from plastic to hardened steel. Brass and mild-steel seem popular.
                                                  None of my books explain anything, but I suggest 6 reasons for fitting plain washers:
                                                  • To spread the load so the nut doesn't crush a soft material, or have the sharp edges cut into it as the nut is tightened.
                                                  • To avoid the nut damaging painted or plated surfaces put on to protect the underlying metal against corrosion.
                                                  • For cosmetic reasons – looks neater, and keeps paintwork safe.
                                                  • To bridge gaps when the hole is larger than the bolt, as when fixing a panel through holes slotted to simplify fitting. (No need for the holes to be accurately positioned – the washer covers up a wide tolerance.)
                                                  • To grip something that might otherwise be squeezed out at the nut rotates, such as a wire in a screw terminal.
                                                  • By provide two bearing surfaces, the washer reduces friction as the nut is tightened, making an ordinary spanner slightly more effective. The nut is tighter, and the bolt tensioned better.
                                                  Another mystery my books don't answer is thread angles. Metric and American bolts are both 60°, Whitworth is 55°, Lowenherz 53.1333°, and Thury and BA are 47.5°. Just guessing, but within the range of practical thread angles I think 60° provides the strongest thread, whilst the weaker 47.5° angle provides higher friction and is less likely to come undone. Does anyone know the actual answer?
                                                  Nick Wheeler
                                                    @nickwheeler
                                                    Posted by Mick B1 on 30/01/2021 11:40:54:
                                                    I do the same for all the same reasons. An ordinary stamped washer is so cheap that I would need a good reason not to use one two.
                                                    #523672
                                                    Tony Pratt 1
                                                      @tonypratt1
                                                      Posted by Nicholas Wheeler 1 on 30/01/2021 12:18:00:
                                                      Me too, seems the right thing to dosmiley
                                                      Tony
