washer narrower than thread?!
Home Forums Related Hobbies including Vehicle Restoration washer narrower than thread?!
  • #34329
    bugbear6502
      @bugbear6502
      bugbear6502
        @bugbear6502
        I have a (rather nice) Makita hedgecutter; its only vice is that the screws that hold the blade in place keep working loose, so I have to keep taking the cover off and tightening them.
        They're Phillips, which doesn't help.
        So I went to my local supplier, and bought some nice M5 pozidrive machine screws.
        I removed the old bolts, and attempted to get the washer and split washer off, for re-use.
        Uh? They wouldn't slide down the bolt? I assumed the bolt had simply been badly burred, so I used "quite a lot of force". After that, getting the washer off has essentially stripped the thread.
        I now believe that the thread was rolled onto the bolt AFTER the washers (plain and crown) had been put on, hence the threaded portion is larger than the shank with the washers.
        Has anyone else (ever) seen this – and why would they have done it?
        BugBear
        #251572
          Posted by bugbear6502 on 20/08/2016 08:27:23:
          • Yes [and there is a technical name for them, which I don't recall]
          • to stop the washers falling off and you losing them … It's actually more likely that they do it for manufacturing convenience; but let's give 'em the benefit of the doubt.
          Sems [or more properly SEMS 'cos I'm pretty sure it's an acronym] is what escaped me.
          http://www.pencomsf.com/screws-categories/screw-design-guide/#how-screws-made
          Edited By Michael Gilligan on 20/08/2016 08:42:20
          #251573
          MichaelR
            @michaelr
            Could be Captive Washers Here
            Mike.
            #251574
            Bazyle
              @bazyle
              The washers have a single turn thread sort of bent into place (probably self formed) which screws on as it is assembled and then the actin of tightening flattens off that thread start so it won't restart as a thread backwards. 'self retaining screw; extremely common without washer eg the changewheel cover retaining thumbscrew on any Boxford lathe.
              #251575
                Bazyle,
                You may find it of interest to follow the link that I provided.
                Ajohnw
                  @ajohnw51620
                  Posted by Michael Gilligan on 20/08/2016 08:50:15:
                  Bazyle,
                  Bazyle is just describing a form that has been around for a long time and might even be more common when they are used to fasten thin items down. The washers can sometimes be screwed off by setting them at the helix angle of the thread but they are still likely to be pretty stiff and need tools.
                    Yes, John
                    #251580
                      Unfortunately, this video is not very well-focussed, but it does give a fair idea of how SEMS are manufactured.
                      Anonymous
                        Posted by Michael Gilligan on 20/08/2016 08:35:44:
                        That's precisely why it is done; it's all about money. You only need to buy and inventory one part. During assembly only one part needs to be picked instead of three, which then need assembling before installation. It prevents parts getting missed. Can you imagine the outrage vented on this forum if an item was bought only to be found to have missing washers? teeth 2
                        #251585
                        Ajohnw
                          @ajohnw51620
                          There are some " real " bolt making machines on these. laugh The steam plant seems to be missing,
                          I haven't seen vibrating hoppers working in the uk for a long time.
                          bugbear6502
                            @bugbear6502
                            That's perfect – and since it appears to be done for stock control and/or manufacturing convenience, it's not something I need to worry about for my replacement bolt.
                            Thanks to all for the (great) info.
                            BugBear
                            #251589
                              @mike89748
                              Nobody has suggested a practical cure for Bugbear's problem. I'm sure a smear of a grade of a thread-locker which allows disassembly would do the trick.
                              #251593
                              Perko7
                                @perko7
                                I'd just buy new washers and not waste creative time trying to re-use the old ones.
                                #251594
                                Ian S C
                                  @iansc
                                  I reuse quite a few of these screws , and at times spend a bit of time with side cutters cutting the washers off, I have also used a junior hacksaw, and the Dremmel with a cut off disc. Most of the ones I find are split spring washers.
                                  Ian S C
                                  #251597
                                  Hopper
                                    @hopper
                                    +1 on Loctite. Blue threadlocker should do it.
                                    #251617
                                    bugbear6502
                                      @bugbear6502
                                      Posted by Mike on 20/08/2016 10:59:29:
                                      The "cure" is the fact that I don't need to do anything special; I thought it might be a special secure fixing that I didn't know about.
                                      BugBear
                                      #251622
                                      Ian P
                                        @ianp
                                        Bugbear
                                        Rereading your original post a 'cure' is what you need so you dont have to keep dismantling the hedgecutters.
                                        Mike and Hopper both suggested a thread sealant and I second (third) them.
                                        Nothing at all wrong with Philips screws as long as you have the correct driver.
                                        Ian P
                                        #251626
                                          Posted by Andrew Johnston on 20/08/2016 09:56:51:
                                          It doesn't seem to be the subject of debate these days but one upon a time ME was full of letters stating washers did not exist in full size, only in (bad) models
                                          bugbear6502
                                            @bugbear6502
                                            I can confirm that the original bolt had what I suspect to be thread lock (of some kind) on it.
                                            BugBear
                                            #251665
                                            Spurry
                                              @spurry
                                              You could always add Nord-lock washers to the bolts. I found them on my mower blade M12 retaining bolts. According to the blurb, they are supposed to be good…but time will tell for me.
                                              There are some on EB: 262489261477
                                              Pete
                                              #251667
                                              bugbear6502
                                                @bugbear6502
                                                Posted by Ian Phillips on 20/08/2016 19:12:21:
                                                Bugbear
                                                Agreed – I was so tunnel-visioned on my washer problem, I was ignoring my real problem. Apologies.
                                                However, I taking the trimmer apart to measure/check all this, I've found what I believe to be the fundamental problem – the cutter bar is partially broken.crying
                                                "darn"
                                                BugBear
                                                #251688
                                                Ian S C
                                                  @iansc
                                                  Got a couple of hedge cutters, a Makita battery one uses low profile nylock nuts, the Black & Decker mains unit uses plain nuts, I got it at a garage sale a week ago, I checked the screws when I first got it home as I oiled it, then tried it out on a shrub up the drive way, all ok, so it's put away till the hedge growth starts again. I would reacomend the nylock nuts.
                                                  Ian S C
                                                  #251889
                                                  Dinosaur Engineer
                                                    @dinosaurengineer
                                                    If a thin washer is "dished" with a close fitting hole then when the bolt/washer is fitted, the washer flattens and is held capitive.
