Hi Dave
Sorry to hear what happened – but hopefully it won’t be long before your lathe is back up and running.
This idea is a little bit ‘after the horse has bolted’, but after reading your post it is exactly the sort of thing I might accidently do. To try and avoid the mistake I’ve removed the handles from both the carriage and the cross feed power engagement. When I’m using either, I connect the handle to just the one I’m using. i.e. If I’m using power cross feed, the leaver to operate the carriage isn’t there – so I can’t accidently pull it.
David
