Its a pain having to keep logging in to post……!
Ok,trying something different.
Set P12 to 1, not zero.
With the link in place at terminals 1&2, now, does the drive show STOP?
If it does, then press the START key, the display should say H 0.0 if it does, press the UP key and the motor should speed up, conversely pressing the DOWN key, the motor should slow…..
You did wire the motor to DELTA didnt you ?
