The KB speed control boards do not have any supply capability for peripherals….
It is conceivable that the filter board may have a 12 v supply integrated, as has my big lathe…
As an aside, wnen I converted my Chester 9 x 20 to 3ph, the original motor had a 14 mm shaft, the new mitor I got had a 19 mm shaft, rather than have to make a new pulley which was a special anyway, I machined the shaft on the motor…..Motor dismantled, rotor supported with a live centre in the tail stock, and diameter reduced as required…
QED….
