Hi everyone,
I’m just rebuilding my WM240B after a bit of a winter strip-down and clean.
Does anyone think it is worth putting the bed on levelling feet? It’s sitting on a bench made of two sheets of 25mm plywood sandwiched together and bolted to the wall and box-section steel legs, which are in turn bolted to the floor. The lathe itself is bolted down – although I now see that there are a variety of views on whether this is a good idea or not – and has a number of shims packing out each corner as required to achieve reasonable level.
Seeing as everything is stripped down, would it be advantageous to introduce the feet, for easier levelling?
What do people think?
Thanks,
Jerry.
