Warco wm18 mill
Warco wm18 mill
Home Forums Workshop Tools and Tooling Warco wm18 mill
  • #168604
    Brian Abbott
      @brianabbott67793
      Hello all..need some help ( again… ) is possible…
      Went up the shed last night to try and do a bit.
      Whilst using the mill the table felt notchy in the X ( was ok last time i used it )
      Would guess i have got something in there, any ideas how i remove the table ?
      quick look would suggest if i remove the handles and end covers the table should slide off
      thanks
      Brian Abbott
        @brianabbott67793
        Notchy table
        #168618
        Yngvar F
          @yngvarf
          I think this is the same machine as Weiss wm-30? If so:
          Remove gib adjusters. Tap out the gib.
          If you remove handle and end cover on one side, then remove end cover screws on other side, the lead screw can be removed.
          Table can be lifted off
          By the way, have you checked the thrust bearings on the handle.
          Yngvar
          #168643
          Brian Abbott
            @brianabbott67793
            Very good point about the thrust bearings, think i will look at those first..
            Thanks Yngvar..
            #168730
            Brian Abbott
              @brianabbott67793
              Hello Yngvar..
              Stripped the table of tonight, gave all a good clean and a coat of oil, cleaned and greased the thrust bearings and all seem good again..
              One question if I may, is the gearbox sealed or should I be oiling something?, sorry if this seems a daft question but the machine is quite new to me..
              thanks for any help, Brian
              #168759
              Yngvar F
                @yngvarf
                Hi Brian
                I've just put some grease on the gears from time to time.
                If you turn the head 90 degrees you get access through an inspection cover at the back.
                Yngvar
