Martin …..I had another look at the mill this morning and remembered that to oil the right hand end of the slideways requires dismantling the right hand end plate/winding handle housing as it fouls the slideway ….in fact comes to a dead stop when wound right in, without exposing the slideways. I suppose that it would be possible to machine away some of the back plate to allow it to pass over the slideways but I am not sure where that will lead me to! This is the difficulty I recall from past attempts. Obviously you do not have that problem? It does seem odd that no better provision is made for lubrication.
Mechman….thanks for the ideas but the one shot seems a bit extravagant for this job and I can do without trying to squeeze even more kit around such a small machine. I think that I am right in saying that the WM16 has a much greater traverse than the WM14 which is less than 12 inches. I now wish that I had gone for the WM16. As the usual good advice goes, always buy a bigger machine than you think that you will need.
John…..this looks like a good way to go if I can get the grooves machined.
Mick
