I find Warco's suggestion not appropriate without basis. But hey what do I know? I didnt supply the machine…
So, as this is a dc motor powered mill, I suggest the following:
With the mill unplugged from its mains supply. Check the motor brushes for condition, length and a free to move in their holders. If they look ok, proceed as below…
Ensure the mill is unplugged from the Mains while working on it….Make a note if you disconnect any wires, so you know where they need to go back!
Disconnect the motor wires, then with a 100 watt domestic lightbulb in a suitable holder, connect to where the motor was connected….Power up the mill, and the bulb should vary in brightness as the speed control is advanced…Does it do this?
Test the motor with a 12v batter, while it is disconnected from where it was connected to, in the above step. The motor should turn freely with no undue noise and sparking from the commutator.
Please report your findings, then we can advise accordingly…..
