Posted by JasonB on 07/11/2021 18:27:09:
As you said in another post you had stripped 4 gears in 12months I wonder if you may also be taking too heavy a cut with a hobby machine.
By installing upgraded gears you have removed the weakest link from the train, now you don't have a sacrificial gear to protect the motor from overload.
No, it's just a fact that the soft plastic gears, as supplied with these Chinese machines, are too soft and don't like high temperature – and as most owners of these mills have found out strip readily.
When working with steel I generally don't take much more than 0.2mm with a milling cutter – and as this isn't generally for exytended periods, there are usually no problems with overheating (anlthough the motor does still get very hot).
The motor has obviously not failed due to overheating but it does start to smell and smoke is visible – this generally happens during fly cutting operations where there is a single point cut over a larger diameter – although I generally don't risk more than around a 0.05mm cut with steel.
I have not removed the "weakest link" from the system. The "upgraded" gears are still the weakest link in the system – although they are now made of engineering nylon PA2200 which has a higher melting point and is much stronger than the soft gray plastic version (which people think is delrin or similar).
The nylon gears have been installed by quite a few users and are definately an improvement – and are also more readily available (and actually cheaper) than trying to get replacements of the stock gears from any of the UK milling machine suppliers.
