How much work can be got out of a hobby mill before it overheats or strips gears? Good question! Two different problems:
- gears are more likely to strip under shock loads, as when a speeding cutter crashes into something solid. The motor could be running within specification when the crash happens, and the gear breaks to protect the drive train and to limit the heavy current pulse pulled by a stalled motor.
- Motors deliver more their rated power when the user overloads them. Plastic gears are unlikely to strip under a steady overload, but the motor will overheat. The gear isn't useful as a fuse and if the user persists, insulation, brushes and electronics are all likely to be damaged.
Therefore the operator should avoid crash-bang cutting, and back off when that type of cut is unavoidable – adjust RPM, depth-of-cut and feed-rate to minimise the risk of damage.
To get a feel for how heavily a particular motor is loaded by the operator, I suggest measuring the input with a cheap wattmeter (example of type here). Note how much power is consumed when idling, and how much during a normal-to-you cut. The motor is working to full capacity If the wattmeter registers motor rating + 10%. And the motor is overloading if the wattmeter registers more than that. Overload is a silent killer; the operator may not know anything is wrong until the motor fails outright, or the dreaded magic smoke appears!
Hobby motors are unlikely to be rated for continuous output at full-power. As a result they gradually overheat unless a busy operator pauses to let them cool down. Not a problem in my workshop because I rarely remove lots of metal in one go, and spend ages resetting work and thinking. However, when I do a lot of work on a large lump of difficult metal, I run the motor for 10 minutes, then let it cool for 10 minutes, and repeat the cycle until finished. If the motor is accessible, check how hot it is with the back of your hand: give it a rest if the case is uncomfortably hot. If an owner often finds his machine gets hot, he needs a bigger machine! If that's not possible, take more time.
There's a reason Industrial Machines cost 6 to 20 twenty times more than hobby kit. They're very substantially beefed-up to slog through production work. We have to remember hobby machines are comparatively delicate.
I don't know if the plastic gears in these machines are fuses or cost-cutting. Possibly neither! Another common reason for using plastic gears is they are much quieter. Only the designer and production engineer would know for sure, the rest of us are just guessing…
