Good start. I wonder why you didn't receive any replies. ![wink wink](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
Well you're in luck – there are no kits for these machines AFAICT.
I have the Warco Super Major and I've been considering converting it for a while.
The issue I have is; I'm sure the project will entail machining parts to make it work, but without a 2nd milling machine, this would entail continually disassembling it, taking some measurements and reassembling it again to make the part, which sounds like a faff. Maybe the process would be easier now that I have a 3D printer, as I can mock up all the required pieces while the mill is disassembled, and only assemble once to make the final parts.
