Hi Paul.
What year is your machine, my VMC dates from 1997 and was made in Taiwan and has table feed screws that measure around 22.2mm. The current slightly heavier built Chinese made versions may have something different.
Regarding the dovetails, certainly on the Taiwanese version they can be a bit of a mess, as well as other mating faces on the head and turret which I have corrected. While the ground finish of the guideways on the column, the underside of the table and the top of the knee of my machine are excellent, its the 'hand finished' surface of those on the vertical face of the knee and the underside of the saddle where the massacre has taken place.
It's clear that the tools used for this brutal butchery on mine range from rough files, angle grinders and a big scraper of some sort. They have dug out a concave surface on the saddle and knee leaving four raised areas and then concentrated on these to get the alignment. It is possible to insert a 20 thou feeler gauge between the slides in places. The poor contact area left by this has led to scuffing and early signs of wear on the nicely ground surface that they mate with.
Despite this, and using much better quality machinery over the years, I have always liked them and it does perform very well in a home workshop. Years ago I visited the Myford works and was shown into one of the back rooms. In here was a new Warco VMC they had been looking over, and they hated it, amongst other things making much of being able to stick the feeler gauges in between the slideways.
Myfords own version of the VMC was a different machine, Warco used to offer an identical type in the 1980's. I think the Myford VMC had just been discontinued, and Malcolm Townsend of Myford recalled to me one of the few problems they once had with it was the manufacturers habit of using a bit of emery tape on a stick of wood that they would ram up the spindle to 'finish' the taper. They quickly put a stop to that.
Edited By Lathejack on 22/01/2014 22:12:37
