Hello
Moving up to accurate tool sharpening. Have come down to two options which both on the face of it do exactly the same – Warco UNIVERSAL TOOL & CUTTER GRINDER v Hemingway;s Quorn Mk 3. One, in theory, comes ready to grind, the other needs a few hundred hours of work before its ready to sharpen the first tool. Is there any advantage with the Quorn Mk 3, other than get it right and you have a Royals Royce machine. And is the Warco a sound, robust machine as it seems to built under a number of guises, but is ready to go.
Third option is the Hemingway's Worden Mk3 Tool & Cutter Grinder which requires some work but is not a major project and is nice and compact, but seems very pricy compared with the Quorn.
I will be sharpening all types of lathe tool, milling cutters, slitting saws and drills.
All advice welcome. Thank you.
