Warco Super – Major Vario inaccuracy
Home Forums Manual machine tools Warco Super – Major Vario inaccuracy
Viewing 25 posts - 76 through 100 (of 135 total)
  • #396486
    Robert Askew
      @robertaskew15193
      06ed62bc-e8ef-477f-ab50-17a4e9143f95.jpeg401784fe-3417-4439-8c51-794d08a1c662.jpeg677f5f92-e374-4c5c-8bcc-e6f036b1b5cf.jpegHere is my clock readings
      Edited By Robert Askew 1 on 15/02/2019 21:45:57
      FMES
        @fmes
        Robert, if you are holding that DTI in a chuck and not a collet that is probably where a lot of your error lies.
        Unfortunately we can't see wht you are doing.
        #396488
        Robert Askew
          @robertaskew15193
          it’s held in an er32 collet
          #396489
          Former Member
            @formermember32069
            #396502
              Posted by FMES on 15/02/2019 21:53:59:
              As the dti is not being revolved it makes no difference how it is held or on what part of the machine it is fixed to.
              Your first photo shows the DTI on something laid across the table but the last seems to show it directly on the table but there is 0.008" difference between first and last reading.
              #396505
                Posted by JasonB on 16/02/2019 07:00:54:
                I think you will find that the slip is still there, Jason
                … its edge is the diagonal line just to our right of the DTI probe
                … and there is a reflection in the surface.
                  Possibly something in the last photo but not good practice to move the item around when taking the readings, should be laid across the table and then the table wound across. For best results swap slip end to end and take measurements again to eliminate taper in slip.
                  Also best to get rid of the spring adjuster on the DTI stand
                  Edited By JasonB on 16/02/2019 07:31:05
                  #396507
                    I'm not sure of how these measurements are being taken. You said you wound the table front to back and got 0.008" difference. yet looking at the two photos taken from the end of the table the dti has been moved or swung.
                    This one is taken from the right of the machine as you can see the handwheel bottom left
                    But this one has been taken from the left hand end as you can see the bellows and DRO wires
                    So either it has been swung and that is a tram measurement or the photos are posed and don't show slope on the table.
                    Edited By JasonB on 16/02/2019 07:47:37
                    #396508
                    Ron Laden
                      @ronladen17547
                      Posted by JasonB on 16/02/2019 07:29:34:
                      Jason, I always use my DTI with the spring adjuster fitted, can they throw up errors..?
                      Ron
                      #396510
                        Yes
                        #396513
                        Nicholas Farr
                          @nicholasfarr14254
                          Posted by Ron Laden on 16/02/2019 07:52:19:
                          Ron
                          Hi, I agree with Jason that these spring adjusters will throw up errors and they a not always consistent errors and especially when chasing the accuracy the OP is after. Your DTI needs to be as ridged as possible.
                          Regards Nick.
                          #396515
                            Just for completeness this is what I would have expected to see via way of setup when "turning the handwheel" which will give an indication of how true the top of the table is to the dovetails. You seem to have shown photos of teh spindle being rotated as per my earlier video.
                            #396516
                            FMES
                              @fmes
                              Jason, the background looks like its changing in eack of the photos so it is being rotated, Robert confirms he's using an er32 collet – in an R8 holder??
                              Why not an R8 collet? going from R8 to ER32 may well have introduced errors if not spotlessly clean.
                              In any case, it would be far better to allow the Warco staff to come and have a look at it and advise accordingly rather than play message ping pong trying to diagnose a problem from afar.
                              #396517
                                FMES I have also posted above that the photos seem to show the dti being rotated which was not what was said hence my comments.
                                Until it can be confirmed what test was actually done and how then we can't help much as one result is fixable and the other not.
                                I would also say if tramming the table as the photos seem to show then don't have the vice sat on one side of the table as can be seen as it WILL affect results.
                                #396524
                                Former Member
                                  @formermember32069
                                  #396526
                                  Former Member
                                    @formermember32069
                                    #396529
                                    Robert Askew
                                      @robertaskew15193
                                      Well I will know for sure this afternoon
                                      the maintenance guys from where I work are coming this afternoon with all there test equipment to tell me how far it’s out
                                      and before I get comments on how good they are we work for a well known helicopter manufacturer
                                      #396531
                                      Nicholas Farr
                                        @nicholasfarr14254
                                        Posted by Robert Askew 1 on 15/02/2019 16:35:35:
                                        .008” over full with of table 8.5 “
                                        Hi, am I missing something here. Your DTI is reading a tad over .08mm, which in my book is around .003"
                                        Regards Nick.
                                        #396532
                                        Former Member
                                          @formermember32069
                                          #396533
                                          Former Member
                                            @formermember32069
                                            #396534
                                            Chris Trice
                                              @christrice43267
                                              One could simply machine a block of something and then check for consistency of thickness as at least an indicator of what is going on. A sheet of paper under the block will help stop marking the surface if it needs to go back. My first test would be clamp a piece of aluminium L section along the y axis, skim the upright edge and then measure it.
                                              Edited By Chris Trice on 16/02/2019 10:21:19
                                              #396535
                                                Hi Bob,
                                                I hope you don't think the posts questioning your measurements are unhelpful. Rather they are trying to confirm whether you have a genuine problem or not. No advantage to you rejecting an acceptable machine due to a misunderstanding – though it sorts out in the end, the bother and hassle of making a return is considerable!
                                                Background to the questions is a forum history of chaps buying new Chinese for the first time and starting by taking dodgy measurements to prove to themselves the machine is OK. The problem is that taking accurate measurements demands a level of understanding, skill, and technique that not everyone has. It's not easy and beginners often get it wrong. Actually, experts get it wrong too, it's just that they are alert to the possibility and don't automatically trust anything! Sometimes these chaps are right, sometimes they're just torturing themselves.
                                                One hint that mistooks may have been made is posts saying something like "x Axis spot on front to back y axis.008 out". Suspicions of beginnerism arise because units aren't specified, nor the distance over which the slope was measured. Also, there's no information in your posts about the method used to take the measurement, plus a sense of a man in hurry! From my armchair, it suggests – probably wrongly – that your measurement technique might be the problem.
                                                I suggested earlier that you test the machine by cutting metal and looking at the results. The advantage is cutting shows what the machine is actually capable of rather than inferring what it might be. Also this type of simple test is less error prone. Of course, if the machine produces poor results, then you measure the machine to identify the cause.
                                                None of this questioning means we think you are wrong, only that it saves you a lot of bother by confirming you're right. It's entirely possible that your machine is faulty or out of adjustment. On first installation, adjustment errors do happen as a result of transport, lifting into place, operator error, or a problem with the stand. These can be fettled. But although Chinese machines seem to have improved over the years they aren't assembled or inspected to high standards making it possible yours is a wrong-un.
                                                The best resolution is that an ordinary non-intrusive adjustment fixes the problem. Second best is Warco replace a faulty machine with one that's within spec. Third best is you get your money back and start again.
                                                If your measurement is correct, then the tilt is about 7x what it should be – not good.
                                                Bob n About
                                                  @bobnabout
                                                  My setup for tramming the mill and setting the table or accessories bolted too it.
                                                  I'm not going to fret over the vice being present or some bits of tooling on the table, the power feed is hanging off the left hand side !!!
                                                  My front to back readings, note the indicator is at the same angle and lever adjusted to reduce cosine error.
                                                  For tramming the head I move the vee blocks around the table to get best readings. 300mm in X, and about 200mm in Y
                                                  The machine here is used for work, so I am not going to spend hours chasing precision an order of magnitude greater than required. This really is good enough and no doubt that will shock the purists, but hey.
                                                  And finally.
                                                  Those eagle eye'd will notice my mag mount hanging off the drill chuck. If your spindle is that bendy, machining metal ain't for you my friend. I can set this up get the mill as true as I need it in the space of a few minutes.
                                                  #396578
                                                    Ron
                                                    I recall JS telling me the best improvement to any of those stands is to replace the sprung bar with a solid rod.
                                                    N.
                                                    #396919
                                                    FMES
                                                      @fmes
                                                      Posted by Robert Askew 1 on 16/02/2019 10:10:58:
                                                      Come on Robert, don't keep us in suspense, what was the outcome?
