Hi all
Just got a Warco super major vario mill (new) . Manged to get it onto the stand.
Just two questions –
How on earth does the threading facilty work, have got to point of selecting the threading via console and spindle starts when quill is lowered but doesnt stop until quill returned to stop.
So if I where to use a tap once it had started tapping I cannot stop the spindle, without it appears returning quill back which of course you cant do whilst its still tapping ?
Having got machine on the stand and not tightened down as per warco suggestion so as not to warp base, I commenced to clean up the slides and dovetail above the head unit, then re oiled and raised head fully up and cleaned lower section and oiled, on dropping head back down either by power or via hand wheel it gets two thirds down then stops fractionally and then jumps down as though taking out the play out of lead screw does this nearly to end of travel.
I have tightened the gib and tried loosening it but it still judders down in that bottom section albeit not so much with gib really tight.
Sorry for the length of post but I am sure it should be smotth both up and down, it concerns me that isnt very precision and should it drop when bringing tool or drill close it could slam into work piece,
Any suggestions or is it a possible return it to warco – I shall be ringing them to see what can be down
Thanks
