Hi Gareth
I've recently bought a Warco 250V Lathe and am very pleased with it, and the service I have received from Warco has been very good and pleasant. Their communication has been top class. I should say that I am a total beginner with ME.
In case you are also a beginner you may want to take note of a mistake that I made when I received mine. I believe that Warco do a certain amount of testing / adjusting before shipping – the 'setting marks' on my tailstock appeared out of alignment and one of the first things I did was to move it back to the 'zero offset' mark – big mistake for me that was as the 'zero' setting was obviously wrong when I did some test turning! I now wonder if they had possibly already set it correctly before shipping, having nothing to use to set it back correctly was a problem and eventually used the 'ruler between centres' method (and managed to damage the locking screw in the process giving an intermittent problem – I've now replaced with a capscrew and all is well), yes in case you are wondering I didn't even make a note of the setting before moving it, very silly I know.. Not being sure how accurate the ruler method was I recently forked out for a test bar, and discovered it was only out by 2 thou! Could have maybe avoided the hassle though with a new machine if I hadn't jumped in without thinking and testing first…. Its good to have the test bar now though and have it bang on – and I have some taper turning to do shortly.. The offset marks on the tailstock definitely do not line up as expected when it is correctly set – on mine anyway.
Mine came with lots of extra's included in the price and was I think a very good deal – although I did pay for it to be shipped with Warco's own QCTP, that was a good decision – I find it to be excellent quality and nice to use, not cheap though..
I think the lathe is great and will eventually upgrade with them again.
All the best with it if you go ahead.
Cheers.
Allan.
Edited By Allan. on 05/04/2015 15:04:39
Edited By Allan. on 05/04/2015 15:07:20
