John,
No he made the gears, there is a photo showing it setup on the mill. One is a very thin ring gear and the main one is a 127 tooth helical and the helicals are handed, some RH, some LH just so the software can work in imperial.
I think about 7 gears in total, all having to work with no backlash but not much drag as he's chosen an old design of type 34 stepper that is nowhere near as powerful as the modern 23's
As regards LinuxCNC if feel that it is getting to be the way to go forward, note the " to go "
All it will take is for someone to take the reigns and come up with a workable GUI or screen set for the rest.
If Linux had had a decent screen set or easy way to design one at the outset then it's my firm belief that mach3 would not have the hold it has today.
I don't think I'm breaking any confidentiality agreements when I say I have seen the new Tormach lathe software which is based on LinuxCNC.
However they have gone about it the right way, sat down and discussed what is wanted, then employed a programmer to give them what they want. It looks really professional, clear and accurate graphics, nice colour scheme, grey on black and multiple tabbed screen , much like Mach with tools, offsets and ATC screens.
So yes I can see it being the way forward IF someone will take it to the next step.
