Warco HV mill
Warco HV mill
Home Forums Model Engineer & Workshop Warco HV mill
Viewing 25 posts - 1 through 25 (of 40 total)
  • #507815
    Robin
      @robin
      New toy, still on a pallet, first impressions…
      The table is wound up as far as it will go before a stray bolt head collides with Y slide concertina. Plenty high enough.
      If the table was wound all the way back, it would have torn the X axis DRO scale off 5" below this.
      It is not ISO30 as is claimed on their web site, it is a much more useful INT30.
      I wondered what size the horizontal arbour would be. It came with two, joy unbounded, 22mm and 1".
      If you need to turn the head 90 degrees and duck through the garage door, there is a vertical locator pin that needs to be pulled. The pin is threaded so tighten the nut to pull the pin. Lucky guess. Dipping the control panel was tricky, I am not sure why but my son required a 2 lb hammer to reinstate it. The pallet adds 6" to the overall height.
      There is a ghastly chuck guard that has a switch to see if you leave it open. The switch connects pins 4 and 7 in the electric box when the guard is closed. This bears no resemblance to the circuit diagram but I will postpone rewiring until I feel sure there are no problems in the overall construction. It looks festooned, in an industrial kind of way, needs sorting out.
      More soon wink
      Robin
        @robin
        #507817
        Bo’sun
          @bosun58570
          Hello Robin,
          I realise it's probably small comfort, but I've found Warco Customer Service to be extremely good. I just wish they'd take a closer look at what they're shipping out and promising their customers.
          #507818
          Thor 🇳🇴
            @thor
            Congratulations with your new toy, looks impressive. I wish I had room for something similar in my tiny workshop.
            Thor
            #507832
            Ex contributor
              @mgnbuk
              Different names – same animal.
              Nice looking machine.
              Nigel B.
              #507835
              Steviegtr
                @steviegtr
                That looks very substantial. Nice.yes
                Steve.
                #507837
                geoff adams
                  @geoffadams14047
                  nice machine have fun with it
                  Geoff
                  #507893
                  Robin
                    @robin
                    It is impressive, pictures do not do it justice laugh
                    The advertised motors were 2hp vertical and 1.5hp horizontal.The actual motors are plated 3hp vertical, 2hp horizontal.
                    Compared to my old Major the quill is delightfully rigid, I am going to have fun with this. Heck I am having fun and I haven't switched it on yet laugh
                    #507973
                    Robin
                      @robin
                      It doesn't work. As soon as I press the green button under the lightning bolt the house RCB 30mA trip pops causing SWMBO to moan.
                      Warco technical support are out sad
                      #507986
                      Tony Pratt 1
                        @tonypratt1
                        Bloody hell, £6k plus & it blows your RCB.angry
                        Tony
                        #507988
                        Martin Connelly
                          @martinconnelly55370
                          From experience with that type of chuck guard I predict it will soon be removed and the centre of the black plastic assembly turned to the closed position so the machine will work without it. It's a legal requirement for industry to have a chuck guard which is why they are fitted. The style you have just catches on things and soon gets broken.
                          Martin C
                          #507992
                          Roderick Jenkins
                            @roderickjenkins93242
                            I see it has an inverter drive. Have you any other inverter products ( including the washing machine)? The earth leakages could be adding up to trip your RCB.
                            Rod
                            #508006
                            HOWARDT
                              @howardt
                              Chuck guard is requirement for CE marking and use within a multiple user workplace, what an individual does working for themselves or hobby not a requirement.
                              #508058
                              Lathejack
                                @lathejack
                                Very nice, it looks like a universal mill with a swiveling table. I remember Chester machine tools also offered it, they called it the Model T.
                                Some examples had a gearbox built into the top of the milling head, and a hardened table.
                                #508105
                                Robin
                                  @robin
                                  After searching for RCB 30mA problems I found a link to this very site. On checking I found this mill has a ground connection to the VFD that does not show on the circuit diagram, shall I take it out?
                                  Apparently, Warco's electrician is CoViD isolated and cannot call me back for two days.
                                  I did see the Chester Model T but they don't have any stock. Shame because it has 3 axes on the DRO compared to Warco's 2.
                                  #508106
                                  Robin
                                    @robin
                                    I hear you Howard but there is worse. The handles on the X screw are made like those chuck keys that spring out of engagement the moment you let go dont know
                                    #508131
                                      That is to stop them giving you a whack when you are running the power feed on rapid return
                                      #508178
                                      Robin
                                        @robin
                                        Roger at Warco called this morning, I think he may be sending someone to fix it. Can't complain at that. I have already reinstated the super safety chuck guard.
                                        I am wondering if it really needs a 3hp motor. I removed the 2hp single phase from my old mill and replaced it with a 3/4 hp 3 phase and VFD. It went from growl to purr and has never been found wanting.
                                        OTOH, if it ain't broke don't fix it, this monster sized motor might be lovely, if I ever get to switch it on I will find out wink
                                        #508179
                                        Bo’sun
                                          @bosun58570
                                          Hi Robin,
                                          As I mentioned previously, Warco customer service is very good (in my experience anyway). Hope you get it sorted.
                                          #516320
                                          Mark Slatter
                                            @markslatter13251
                                            Hello Robin,
                                            I was wondering if you managed to get your mill up and running and what your thoughts are of it?
                                            #516416
                                            Robin
                                              @robin
                                              Warco sent some bod around to fix it. If he had told me they gave him the wrong part I could have saved him 5 hours by fitting it myself, the whole thing was coming apart anyway…
                                              I am well acquainted with Warco brass feed nuts, 0.2mm of backlash means you either climb mill or break your tools when it plays catch up. New screws have already arrived.
                                              It had a glass DRO across the back of the bed and a horizontal spindle nose to rip it off the moment you got careless. There is room to fit the DRO under the bed so that is where it is going.
                                              With a vast array of contactors they managed to connect 2 motors to one VFD, with reverse and rev counters. Everything started out at a nice safe 24Vac but then they added a 240V DRO display and a power feed which drapes a 3 core PVC flex across the front of the machine, all 3 wires connected to mains live.
                                              The machine has enormous potential. I am not complaining, I am having lots of fun fixing it up. Fitting Bellville washers to ball screws for zero back lash, plumbing in an oil pump, CNC'ing it, I will soon get to see the gears that wind the knee up and down. They couldn't get back lash in that nut due to the force of gravity so they put extra slop on the bevel gears to simulate it, hoping for a keyway, expecting a taper pin.
                                              Anyway, no insurmountable problems yet, it is going to be wonderful when I finish it wink
                                              #516420
                                              not done it yet
                                                @notdoneityet
                                                So, it not just the bottom end of the hobby market that gets the rubbish designs, built-in hazards and cheap parts?🙂
                                                A month and a half and still not been able to run it safely or satisfactorily? Or are these faults a bit exaggerated?
                                                #516421
                                                Ady1
                                                  @ady1
                                                  It's nice to know that british engineering standards have been maintained over the last 60 years
                                                  Although if you look at the advert on the warco site
                                                  You've got a full sized industrial horizontal and vertical milling machine
                                                  …and you just plug it into the wall like a kettle…
                                                  So there's bound to be a few niggles…
                                                  Edited By Ady1 on 31/12/2020 08:43:36
                                                  #516425
                                                  Ady1
                                                    @ady1
                                                    Technically speaking, the "You're having a laff mate" relay may be tripping out
                                                    #516429
                                                    Robin
                                                      @robin
                                                      No, you've lost me there, translation please…
