The 1440 will almost certainly use Module gears with a 20 degree pressure angle.
My BL12-24 (Warco BH600 / Chester Crafdtsman lookalike) does, 1.25 Module.! Having a Norton box, it only has two changewheels (40T and 32T ) to cover a wide range of Metric pitches, For Imperial mthreads, it only uses the 40T on the input tom the Norton box.
You can find the Module number for the gears by counting the number of teeth on a gear and measuring the OD in mm.
Module = (Tooth count +2 ) / OD
So a 1.25 Mod gear with 60 teeth would have an OD of 77.5 mm
The GH1440 is a current lathe so Warco or Chester should be able to tell you what changewheels should be with the lathe.
Although, being a geared head machine,according to what you see on Google there may not be any need for them, or if there are, they will be few.. There was a comment saying "No need to faff about with changewheels"
Take a look at Hobby Machinist.
There is information to be found if you look in the right place.
