Posted by Bazyle on 22/09/2021 20:10:53:
Counterbalance might help. Unless you need to use a stepper for a cnc application it is a terribly inefficient motor for this application. A traditional solution would be a windscreen wiper with as much reduction gearing as needed. Also perhaps a mobility scooter motor which seem to crop up a lot. Problem then is big enough PSU.
I like Bazyle’s suggestions. No real problem with PSU – drive the buggy motor from a (smaller than the buggy required!) battery and recharge with a trickle/float charger?
Maybe a small three phase motor with a VFD though a suitable gearbox, as a further possibility?
The counterbalance, if possible, is certainly the key to the power required.
Edited By not done it yet on 22/09/2021 21:19:49
