warco/amadeal 250-550 lathe
Home Forums Workshop Tools and Tooling warco/amadeal 250-550 lathe
  • #653245
    Roger Webster
      @rogerwebster39184
      I have the amadeal 250 lathe fitted with a Rocketronics electric lead screw.
      All operates as it should but I notice there is only one half nut and there is some wear on this item after only moderate hobby use
      Does the Warco lathe have a pair of half nuts?
      I intend to modify my lathe and fit a pair of half nuts to reduce the stress and wear on this item
      As a stop gap and to allow the lathe to be used to make some bushes etc I have fitted a 16mm x 5mm pitch cheap ball screw and spindle.
      It works suprisingly well. I was concerned about the increased pitch from 2 to 5mm but no problems so far with fine feed rates and the Y axis motor overheating
      Roger Webster
        @rogerwebster39184
        lead screw half nuts
        #653247
        Clive Foster
          @clivefoster55965
          Roger
          Shouldn't be any wear issues with only one half nut on a hobby lathe. A fair number of respected industrial machines had that configuration with no reported issues of premature wear.
          Colchester and Kerry are the two makes I have experience of having actually seen such nuts in perfectly useable condition after significant use.
          Nut wear is frequently an alignment issue. The requirements are surprisingly stringent and, given the constructional layout, quite difficult when a lathe needs to be made to sell at a hobbyist friendly price.
          #653251
          Roger Webster
            @rogerwebster39184
            Yes I can see there is some miss alignment with wear on the half nut carrier bushes.
            I have made a beefed up double carrier and will attempt to realign the half nut, carrier, lead screw and bushes
            Could be difficult!!!
            #653260
            Ady1
              @ady1
              If it is possible to cast them in situ with babbit then perfect alignment will be automatic
              Edited By Ady1 on 22/07/2023 17:03:13
