Just looked at the pictures!
That is my vertical slide, just a modified fitting…
It is made of aluminium alloy, not steel or cast iron, which may put you off.
Practical travel is well over 40mm.
It's very small, the slots suit 2BA/M5 fixings.
Mine is actually quite rigid – the body is a solid block, not as this one, so I don't have that 50-60mm of overhang….
To use it properly on a mini-lathe means using a raising block, but until I got a mill, I subjected it to a fair degree of abuse.
Bottom, line, I'd get a cross slide mounted one in preference.
