Posted by BOB BLACKSHAW on 11/11/2020 10:10:49:
I have a combination set marked Ministry of Supply. This CWC army watch with arrow.
An expert in military supply could date that watch fairly accurately.
Pre-ww2 items have pattern numbers, where a physical pattern was kept for manufacturers to copy. Later actual patterns became rare, so the numbers became stock numbers, used to identify types of item, not necessarily made to a pattern.
MoS numbers run from WW2 into the 1960s and are broadly tri-service. When the MoS was shutdown, most items were transferred to the MoD and reclassified with NATO numbers by one of the 3 services.
0555 is a Naval Class Group, indicating the watch was ordered by Naval Logistics rather than the Army or RAF. Later, the leading zero of 0555 was changed to an alphabetic 'O' to be consistent with the alpha classes used by the RAF and Army. But the watch also has a full NATO stock number, indicating it comes from the time when military logistics were going tri-service, but the three services were still semi-independent. It's an Army watch bought by the Navy, and probably used by the RAF as well. 99 means it's British.
I suspect a watch bought by the Defence Procurement Agency today would only have a NATO stock number on it, or maybe nothing at all. The US DoD discovered it cost them $140 to have a $10 toilet seat marked up with its NATO stock number!
The need to mark items was a painful wartime lesson, and saving money by removing them may be an unwise peacetime economy. Unmarked items cause chaos when work needs to be done in a hurry, as in the middle of military operation. Serious problem when assets can't be repaired quickly because fittings can't be identified.
