Wanner grease-gun thread ?
Home Forums Workshop Tools and Tooling Wanner grease-gun thread ?
Viewing 25 posts - 1 through 25 (of 38 total)
  • #569444
    Bob Unitt 1
      @bobunitt1
      Does anyone know what the thread is of the 'delivery nozzle' of a Wanner grease-gun (about 20 years old) ? I'm referring to the component that actually attaches to the grease-nipple, as I need to make a smaller one to fit the quill grease-nipple on my Fobco Star drill.
      Bob Unitt 1
        @bobunitt1
        #569448
        Tony Pratt 1
          @tonypratt1
          Can you not measure it?
          Tony
          #569451
          Ian Parkin
            @ianparkin39383
            When i want to grease the quill on my fobco I take the nipple out and grease it with a male ended gun.then put the small nipple back in
            or if you are desperate to leave the original small nipples in situ make a small adapter with a nipple and a short length of tube ending in a fitting to go on the small ones
            Edited By Ian Parkin on 02/11/2021 17:15:30
            #569452
            old mart
              @oldmart
              I would guess that most of the grease gun threads would be 1/8 BSP.
              Here is a link to the Motalis website which is very useful:
              Edited By old mart on 02/11/2021 17:13:18
              #569454
              noel shelley
                @noelshelley55608
                As Old mart, 1/8" BSP ! It is NOT 3/8" UNF ! Standard grease nipples are available in many threads, UNF, BSF,BSP, BA,Metric and many sizes. Good Luck. Noel
                #569466
                Philip Rowe
                  @philiprowe13116
                  I grease my Fobco with my original Myford supplied oil gun, filled with grease. As its pretty useless as an oil gun it has at least redeemed itself in lubricating my drill. Phil
                  #569471
                  DiogenesII
                    @diogenesii
                    Just in case it's useful to any else, here's a link to Stephens Lubrication 'Wanner' page, 3/4 of the way down is an illustrated list of available nozzles for the telescopic guns.. ..no relation to this business, other suppliers are available etc….
                    Stephens Lubrication – Wanner…
                    #569473
                    Bob Unitt 1
                      @bobunitt1
                      I've established it's 3/8" by 28 TPI, but I can't find that thread in my references.
                      #569477
                      Harry Wilkes
                        @harrywilkes58467
                        Just in case you miss counted 3/8x 27 is gas thread
                        H
                        #569484
                        Bob Unitt 1
                          @bobunitt1
                          Posted by Harry Wilkes on 02/11/2021 18:30:50:
                          H
                          No, I tried 27 and it didn't fit. It's definitely 28 TPI.
                          #569485
                          Bob Unitt 1
                            @bobunitt1
                            Posted by old mart on 02/11/2021 17:13:01:
                            I think that's the grease nipple thread ??
                            #569487
                            Maurice Taylor
                              @mauricetaylor82093
                              Hi,I made a new end for a grease gun and the thread was 1/8 bsp ,this is 0.383 in dia and 28 tpi . The same as what you have measured.
                              Drill a hole ,tap it 1/8bsp and see if it fits.
                              Maurice
                              #569489
                              Simon Williams 3
                                @simonwilliams3
                                Hi I've made special nozzles to fit the Wanner pump casting, I used 1/8 BSP (parallel) threads throughout. I'd expect it to be imperial because Wanner IIRC is Swiss so it's unlikely to be NPT.
                                1/8 BSP is 28 TPI.
                                1/8 NPT would be 27 TPI. It would also be a tapered rather than parallel thread form so that's a no on two counts.
                                M10 x 1.0 is close but no cigar, also 3/8 UNF (24TPI) is another near miss.
                                HTH Simon
                                edit – added in italics
                                Edited By Simon Williams 3 on 02/11/2021 20:38:10
                                #569501
                                noel shelley
                                  @noelshelley55608
                                  1/8" BSPP and 1/8" BSPT are BOTH 28 TPI ! It is the thread that is used on a 1/8" nominal bore pipe of .383" od, refered to as nomimal bore to allow for different wall thicknesses and therefore varing bore size. Noel
                                  #569600
                                  Bob Unitt 1
                                    @bobunitt1
                                    Now I know what the diameter and TPI are I can screwcut it, just not sure if the thread angle should be 55 or 60 degrees ?
                                    #569638
                                    Howard Lewis
                                      @howardlewis46836
                                      Since you have measured the OD, use Thread Gauges to establish both the Thread Form and the pitch, then you will know what the thread is!
                                      #569641
                                      Bob Unitt 1
                                        @bobunitt1
                                        Posted by Howard Lewis on 03/11/2021 18:43:40:
                                        It's too small for my old eyes, I can't tell the difference blush
                                        #569657
                                        not done it yet
                                          @notdoneityet
                                          Posted by Bob Unitt 1 on 03/11/2021 18:46:37:
                                          Use a magnifying glass or eyeware?
                                          Just one example:
                                          la-301424804309&gclid=Cj0KCQjw5oiMBhDtARIsAJi0qk1guZdbH0vSOMqB9DBTGXgvms7A60MvhrTwXfnM6JQ90DaW3dCem7AaAisVEALw_wcB&gclsrc=aw.ds”>https://uk.rs-online.com/web/p/magnifiers/2017939/?cm_mmc=UK-PLA-DS3A-_-google-_-CSS_UK_EN_Test_%26_Measurement_Whoop-_-Magnifiers_Whoop-_-2017939&matchtype=&aud-772940708079la-301424804309&gclid=Cj0KCQjw5oiMBhDtARIsAJi0qk1guZdbH0vSOMqB9DBTGXgvms7A60MvhrTwXfnM6JQ90DaW3dCem7AaAisVEALw_wcB&gclsrc=aw.ds
                                          #569663
                                          Simon Williams 3
                                            @simonwilliams3
                                            BSP is 55 degrees included angle, as it is a hang over from the days of Joseph Whitworth Esquire.
                                            NPT is American so is 60 degrees.
                                            Not going to make a discernable difference on a thread depth of 23 thou.
                                            #569669
                                            Howard Lewis
                                              @howardlewis46836
                                              If the Wanner is Swiss made, use a magnifier to check if the thread is not actually 10 mm diameter x 1 mm pitch.
                                              #569702
                                              Bob Unitt 1
                                                @bobunitt1
                                                Posted by not done it yet on 03/11/2021 19:09:41:
                                                Just one example:
                                                My browser didn't like that link, refused to open it.
                                                #569703
                                                Bob Unitt 1
                                                  @bobunitt1
                                                  Posted by Simon Williams 3 on 03/11/2021 19:15:56:
                                                  Thanks, I'll screwcut it until it fits.
                                                  #569705
                                                  Bob Unitt 1
                                                    @bobunitt1
                                                    Posted by Howard Lewis on 03/11/2021 19:49:25:
                                                    Definitely not – 1 mm pitch would be 25.4 TPI, and it's certainly not that. To be clear, I can see the TPI OK, it's just the thread form angle of this small thread that I can't judge by (old) eye.
                                                    Edited By Bob Unitt 1 on 03/11/2021 23:06:47
                                                    Edited By Bob Unitt 1 on 03/11/2021 23:08:07
                                                    #569803
                                                    old mart
                                                      @oldmart
                                                      BSP is still the most widespread pipe thread on the planet, all of the thread angles are 55 degrees whether straight or tapered. The 28 tpi is only used on 1/8 bsp which is the nominal bore of the pipe not the od like non pipe related thread sizes.
