Wallaby crankshaft
Wallaby crankshaft
Home Forums Materials Wallaby crankshaft
  • #519128
    bernard towers
      @bernardtowers37738
      Have reached the point where the crankshaft is next but not sure of best material to use, machinability, wear etc. American builders seem to favour 1144 stressproof steel but am having difficulty finding a European equivalent. Any help will be gratefully received.
      bernard towers
        @bernardtowers37738
        Material
        #519130
        Oily Rag
          @oilyrag
          Equivalents for AISI 1144 are BS44SMn28, BS44SMnPb28, and BS226M44. In more understandable EN numbers the nearest equivalent is EN8M, close but not exactly the same!
          #519135
          bernard towers
            @bernardtowers37738
            Unfortunately googling those bs numbers brings up zilch
            #519137
              This guy does plenty of black EN8 and M-machine do it too
              Leave the "BS" off the other numbers and you will get plenty of results or use EN prefix instead
              Edited By JasonB on 11/01/2021 16:34:56
              #519163
              bernard towers
                @bernardtowers37738
                Jason, thanks for the info but £25 for 6 inches is a bit rich for me!
                #519562
                Roger B
                  @rogerb61624
                  The first question I would ask is what are you going to do with the engine? If it is going to idle for a few hours a year at a show mild steel will be fine. If you are going to haul passengers with it in an 1831 every other weekend then you will need to use something better.
                  #519569
                    Posted by bernard towers on 11/01/2021 18:02:51:
                    Don't know where you went looking but 50mm dia x 200lg black EN8 comes up at £12.33 inc postage from the e-bay supplier as that is smallest dia he does, about a tenner if you contact them and ask for 150mm long.
                    Or M-machine do 1 1/4" bright EN8 which I think you can just get it out of for £6.90 x 300lg plus about £5 postage.
                    Edited By JasonB on 13/01/2021 14:46:46
                    #519571
                      Posted by bernard towers on 11/01/2021 16:24:06:
                      'Equivalents for AISI 1144 are BS44SMn28, BS44SMnPb28, and BS226M44.'
                      They're BS designations, but BS isn't part of the number. Try 44SMn28, 44SMnPb28 and 226M44
                    Home Forums Materials Topics
