Nigel – thank you, I used my deeply ingrained technical skill to select a model from the hordes available i.e. the one with 'flashy lights' and pretty colours !!
It duly arrived and plugged in. The 'flashy lights' bit generated a sequence of leds illuminating in a part circle, the little screen at the top indicating voltages etc and the lower mode annunciators indicating LiFePO4 !!! In the centre of the circle of leds is a small circular area marked 'mode' Pressing this or, indeed, pressing any of the surface 'indicators' produces nothing. The accompanying 'destruction' booklet seems to indicate that these 'functions' should be selectable … but they aren't !
I stopped the process and 'messaged' the seller suggesting that all was not well. His reply, this morning, reads
"our charger can match the charging mode intelligently, please don't worry"
My aged logic says that seeming selection indicators which select nothing, apparent function selectors which do nothing and battery type indicator indicating the wrong battery type are signs of malfunction. Seller, apparently thinks not … any thoughts, please ?
rgds
Bill
