Posted by Les Jones 1 on 01/07/2020 20:28:00:
Hi Robin,
I have some digital calipers that use CR2032 cells but the data output is still 1.5 volts. I think they have a built in regulator to drop the 3 volts down to 1.5 volts.
Les.
Hi Les. This is interesting! Well, to me as someone with little knowledge of electronics anyway. The ARC readout unit can be powered from the mains via a 6V output 'wall wart', or from two internal AAA cells in series, so about 3V. But it puts out 1.7V, so there must be a regulator in the unit which can drop either 6 or 3V to 1.7. Then it presents the 1.7V to the scale, which anyway must have a built in regulator to drop 3V to 1.5. It all seems a bit over-complicated! Can you explain why it's done like this?
Norman – apologies for hijacking your thread, but I'm trying to get to grips with the same stuff myself – glad your question has been answered,
Robin
