There is no British Standard Pipe thread with a 26 tpi pitch.. 1/8 BSP is 28 tpi. Above 1/8 it goes to 19 tpi and then to 14 and then 11 tpi.
If the thread form is 60 degrees, it will be British Cycle thread.
There are no Unified Coarse or Fine with 26 tpi pitches. And, given the age, a Unified thread would be unlikely.
If the form is 55 degrees, it may well be British Standard Brass, Only 1/4 BSF is 26 tpi
What is the OD? Presumably, given the age, Imperial.
