Posted by Martin Cargill on 17/06/2017 09:08:36:
When using screened cable only connect ONE end to earth. That way the screening works and does not lead to the possibility of circulating currents in the screen.
Edited By Martin Cargill on 17/06/2017 09:09:00
Despite much contrary advice floating about I believe that's right. The purpose of the screen is to reduce electromagnetic radiation caused by Radio Frequency currents which are a VFD by-product. What's significant at Radio Frequency is negligible at 50Hz and in this context it's unwise to assume AC and RF are similar. In particular a loop can be an efficient radiator. Look at a TV antenna.
I can't find the reference but the most convincing of my books says:
- single shielded cables should be 'earthed' at the equipment end only
- the inner shield of a double shielded cable should be 'earthed' at the equipment end only BUT the outer shield should be 'earthed' at both ends.
I think the reason advice varies is because much depends on individual circumstances. The length of the wires, the frequencies being produced, the quality of the power earth, and the type of filter fitted all have an effect. Compounding the confusion, unless you have a wide spectrum receiver you can't tell if there's an RFI problem or not. Domestic TVs and Radios are far from ideal as test equipment.
Apologies for complicating Lee's question: don't over-think it! If I were Lee I'd use 1.5mm SY cable with the shield earthed at the VFD end only.
