Posted by DC31k on 06/11/2021 12:54:46:
The challenge using a 2-speed motor with a VFD is that it is not possible to configure the motor to accept 230v three-phase.
As I understand it, the most common way for a two-speed motor to be configured is 'Dahlander wound'.
Fair point, although the motor will still run in star. Just that the power will be down as the phase currents will be lower than when running from 415VAC.
I've got two machines with 2-speed motors, the horizontal mill and the repetition lathe. The motor on the repetition lathe only changes the number of poles. Slow speed only halves the speed and hence is half the power, vis 1hp and 0.5hp.
The horizontal mill is rated 5hp in high speed and 4hp in low speed. So as well as doubling the number of poles it changes from star to delta when going from high to low range. I'm not convinced the motor is arranged according to Dahlander. I suggested this a while ago on the forum and was told in no uncertain terms that it was unlikely to be a Dahlander configuration. To change from high to low speed two knobs need to be changed. One standard electrical switch on the electrical box and one (which I an sure is electrical) on the column of the mill under the speed change levers.
