Posted by not done it yet on 21/06/2022 12:47:15:
Spec for the SB 1024 says no more than two horse power motor. That would not require such large cross section conductors for its three phases.
The motor wouldn't, but the cable requirement might be related to keeping EMC levels down.
Although VFD's produce power good enough to fool a motor it's being fed genuine 3-phase, the waveform is synthesised. Full of high-speed switching artefacts, and there's plenty of radio frequency power in the mix. High frequency AC behaves very differently from low frequency AC, such as radiating from relatively short lengths of cable. The purpose of using fat section cable might be to keep the RF impedance low, perhaps matching it to reduce reflections, and improving the efficiency of the shield.
I used 2.5mm² 4 core SY (from TLC as it happens), which is good for 24A, and should work fine. 6mm² shielded is available if fatter is essential.
I wondered if two different cable requirements are mixed up. The controls are likely to call for twisted pair, and the usual shielded power cable is needed by the motor. Not a special twisted-pair shielded power cable!
