All high npressure pipes that we are likely to encounter will have started as straight pipe, whether cold drawn or Bundy.
The standard sizes doe 6 mm OD [pipes were 1.5, 1.75 and 2 mm.
(Sometiomes a source of confusion when nthe same pipes shape, but different bores wwerr used on naturally asp;irated, turbocharged, and charge cooled engine! )
If the donor was ex R -R, he was probably ex Oil Enginme Division at Shrrewsbury.
