hi Hugh,
As Keith says the simplest way is to lay a 6″ rule across the bar, I use a centre drill in the chuck, set approx in centre, align the point of the drill along the bar and trap the rule gently. Move the table until the rule is horizontal, then you are on centre.
How to check for horizontal? align with a known horizontal, perhaps a parallel or 2 across the machine bed, a spirit level behind it, or you could even use one of those builders laser levels that are so cheap now or even just do it by eye, depends how accurate you need it
. It is surprisingly accurate and no maths.
Terry
Edited By Terryd on 31/12/2010 00:22:16
