Thanks for your input, Gas_mantle. I can see why coal would be difficult below a certain size – something about the difficulty of scaling nature comes to mind. If this project goes well I do intend to build a 6 inch boiler in the future, but the 3 inch is under way, so …
… the firebox I have in mind will be quite wide at the bottom, roughly conical in shape and quite tall. It would be quite unusual in design but the aim is to make a functional device, not to make a model of anything in particular. I'm thinking the shape could generate a decent updraught, especially with a tall smoke stack on the chimney. I have been thinking about routing the exhaust up the chimney, However, instead of a blower I envisage the gentle use of a hand-cranked fan with outlets below grate level. That would blaze up the coal, but would also be very controllable.
The system would be idiosyncratic (fine by me!) but I think it could work so will probably give it a try. It would also look very funky in an unusual way if I get it right. However, what I have taken from these discussions is a decision not to take any irrevocable steps or commit to anything until I have tried everything out with temporary setups. If the coal doesn't work, I'll use gas instead, and nothing lost but at least I will have tried!
Edited By gary.a.ayres on 14/03/2018 21:03:22
