Vertex VTA13-3 tapping head
Home › Forums › Workshop Tools and Tooling › Vertex VTA13-3 tapping head
  • #643104
    Peter Russell 1
      @peterrussell1
      I bought one of these things thinking it would be useful. It is anything but obvious how to use it and there are no instructions. I've searched the web, but all to no avail. Not even a You Tube video!
      The device itself is marked as TC13-MT2.
      Can anyone help me out here?
      Thanks.
      #20988
      Peter Russell 1
        @peterrussell1
        #643109
        Anonymous
          It would help to post a picture of the unit. A quick search for Vertex tapping head gives results that have a passing resemblance to Procunier tapping heads, so they may work in the same way.
          #643112
          DC31k
            @dc31k
            It is a tapping _chuck_ not a tapping head.
            Effectively, it is a 2-jaw jacobs chuck.
            I am not sure what instructions might be necessary.
            Insert square end of tap into device. Tighten. Use. Remove tap when finished.
            https://www.rdgtools.co.uk/acatalog/Vertex-Tapping-Chuck-1-8-1-2—-M2-M12—-VTA13-3-MT2—70676898U.html
            #643113
            ega
              @ega
              My Vertex tapping chuck in operation:
              I find it very useful.
              #643119
              bernard towers
                @bernardtowers37738
                The part that say open?close is adjustable for size of square on tap ,front chuck holds tap central.The way I use mine is to fit tap in outer chuck jaws as a sliding fit then slide tap to the rear and adjust rear jaws to clamp square on tap, tighten front jaws and you are good to go.
                #643449
                Peter Russell 1
                  @peterrussell1
                  Thank you gentlemen. I though it was more than it is.
                  Another misguided purchase!
                  Anyway now I might start to use it.
                  Thanks again.
                  #643451
                  Tony Pratt 1
                    @tonypratt1
                    Or use a drill chuck.
                    Tony
