Vauxhall Omega on Screen Display
Home Forums Electronics in the Workshop Vauxhall Omega on Screen Display
  • #364839
    Clive B 1
      @cliveb1
      Hi
      Does anyone know what's going on, the on screen display in my car has gone dim but only on part of the screen which makes it virtually unreadable in daylight.
      I've taken a photo of it as best I can when it was dark outside, the dim part of the screen I've marked in red.
      Thanks to anyone who can help
      Clive B 1
        @cliveb1
        #364847
        Speedy Builder5
          @speedybuilder5
          looks like the back light is failing / failed. It may just be a bad connection between the wiring harness and the unit – this happened to me on a Clio mk III. If you are into electronics, you may be able to fix it if it is the bulb which has gone, but either way you will have to get some of the dashboard out of the way.
          BobH
          #364853
            If it's anything like a Vectra, set aside a few hours…
            But always try the garage approved fix first. Thump the top of the dash with your fist, a garage tried it and it worked on my wife's Mondeo, saving her a few quid! Just rattles any loose/grubby connectors around a bit and resettles them.
            #364866
            Nick Wheeler
              @nickwheeler
              Just like we told you on the Omega forum, one of the backlight bulbs has blown.
              Cheap part(replace all of them) and is unlikely to take more than 30minutes even with a coffee.
              #364867
              Jon Lawes
                @jonlawes51698
                I'm fairly certain a bulb has gone….
                #364868
                Clive B 1
                  @cliveb1
                  Hi
                  Thanks for taking the time to reply fellas, I'll have to give the back lights a try, which I can't do at the moment because too busy rolling around under our other car which I'm trying to fix so don't want the Omega down also.
                  I did have the dash out some time ago and took this photo while it was out but can't remember if what I've marked in red are backlights, they may well be.
                  #365973
                  Jon Lawes
                    @jonlawes51698
                    Yes those are bayonet fit bulbs (well bulb holders but they usually come as a complete unit), quite a simple fix.
