I've got an old 100-RM Variac, made by Zenith, rated 8 A at up to 270 V. I inherited it with my father's workshop and it has spent several years neglected under various benches gathering grot and swarf. Needing to run up the supply volts on a VFD that's been in storage for 3 years I thought that I'd better give it a bit of TLC and have spent most of the afternoon on it. I've got to the stage where there is good continuity between wiper and coil for most of the track but there's still a bit that's intermittent.
I have dismantled the brush assembly, cleaned it up and lightly re-oiled it and adjusted the springs, I'm wondering if the brushes are too worn. So…
Does anyone know what length the brushes should project from their little carriers? At the moment there's 2.5 mm, the same on each, is that OK or should I try to find or make some new ones?
Thanks in advance for any help!
