Variable transformer
Home Forums Electronics in the Workshop Variable transformer
  • #31951
    Paul White 3
      @paulwhite3
      Paul White 3
        @paulwhite3
        Some 30 + years ago I acquired what I called a variac which has been kept on the "it'll come in" basis, and sure enough it can now be put into use.
        The problem is that I have no idea as to its current capacity, it is marked as follows- cressall, England, drovolt. code2799 (the second 9 in this number is a guess it could be s or even 8).
        I have tried searching the internet with no result.
        Can anybody help me determining the capacity.
        Thanks .
        Paul.
        Edited By Paul White 3 on 20/06/2018 14:07:51
        #358643
        John Haine
          @johnhaine32865
          How big is it? I have one with a known rating (which I'd have to check) so that might give some indication.
          #358645
            A browse through currently available offerings might be a good start: **LINK**
            https://uk.rs-online.com/web/c/power-supplies-transformers/transformers/variacs/?sra=p
            Find something of similar weight and it will probably have a similar rating.
            After that … run some load tests and see when it starts to get warm.
            Edit: Here is a Torovolt on ebay, for comparison
            https://www.ebay.ie/itm/Variable-Transformer-240V-0-6A-Cressall-Torovolt-33Y-Variac-Unused-/192484445526
            and a link to Cressall's web-site: https://www.cressall.com/about-us/
            Edited By Michael Gilligan on 20/06/2018 14:20:37
            #358646
            Paul White 3
              @paulwhite3
              John, that's what I call a response, the winding is 4 inches dia and 1.5 inches deep.
              Thanks
              Paul
              #358648
              KWIL
                @kwil
                Remember it is a variable auto transformer and therefore the output is not isolated from the input mains.
                #358649
                Paul White 3
                  @paulwhite3
                  Michael, another supercharged response, thanks. A quick look through the RS listing has specs that I find just produces more questions. Your last comment – load it and see if it gets hot, is a probable course of action.
                  I hoped in my ignorance that someone may have a spec.
                  Kwil, thanks for the warning. I am not new to the auto transformer I have a large unit that I have used over the years on all sorts of applications but it is a HEAVY unit , this one that is subject of the posting is much lighter .
                  Paul.
                  Edited By Paul White 3 on 20/06/2018 14:42:02
                  #358651
                  john fletcher 1
                    @johnfletcher1
                    Be sure it is intended to work on 240 volt mains, there was a lot of specials made. Have a look on VARIC or Regavolt or Claude Lyon site, there used to be wiring diagrams on them Buck/Boost. Don't forget they auto transformers, NO ISOLATION and do check that the common connection is the NEUTRAL. You may also find details on Vintage Radio site.For clues, please give us the height and width. A very handy piece of kit. John
                    #358658
                    Paul White 3
                      @paulwhite3
                      John, All the information that I have is covered in the first posting and the response to John Haine. the only additional info I can give is the wire gauge of the winding, this is 23SWG ( to the best of my measurement ).
                      How do I ensure its meant to run on 240 volt.
                      Thanks for your response.
                      Paul
                      #358661
                        Posted by Paul White 3 on 20/06/2018 15:41:13:
                        … the only additional info I can give is the wire gauge of the winding, this is 23SWG ( to the best of my measurement ).
                        Possibly good for 0.75A … so I would see how much it warms at 0.5A
                        https://en.m.wikibooks.org/wiki/Engineering_Tables/Standard_Wire_Gauge
                        Paul White 3
                          @paulwhite3
                          Thank you all for your helpful input, subject to the original hope for a spec sheet I think we can put this one to bed.
                          Paul.
