Variable timing for a steam oscillating engine?
Home Forums Stationary engines Variable timing for a steam oscillating engine?
  • #478443
    old mart
      @oldmart
      Looking at the super model oscillating steam engines in the forum at present, I was wondering if any had been designed with variable port timing?
      old mart
        @oldmart
        #478478
          The one I did will vary how much the ports open, a bit like notching up or down on a reverser quadrant so you can run more economically at low speeds/loads.
          #478482
          Maurice Cox 1
            @mauricecox1
            K.N Harris,s oscillating paddle engine model, detailed in his book, has an eccentric driven plate valve, the timing of which could be varied. The book was called "Model stationary and marine steam engines".
            Maurice.
            #478548
            old mart
              @oldmart
              I thought somebody would have done it, I had visions of a pair of concentric rings with the ports in them that could be rotated independently over a few degrees. It would be difficult to make such a system work, unless the engine was a fair size, though.
            Home Forums Stationary engines Topics
