Never stalled my 280 while drilling in the 10 years that I have had it with bits upto 25mm dia. my next size down from that is 3/4" so thats a reasonable amount to be removing in one go. Are your drill bits sharp and how hard are you forcing the drill in?
If I do get a snatch then it's more likely the drill will spin in the chuck
You could try running with alittle less tension in the belt so that acts like a slipper clutch and will give the motor an easier life.
Edited By JasonB on 25/06/2017 07:35:49
