Valve timing
Valve timing
Home Forums I/C Engines Valve timing
  • #381430
    AJW
      @ajw
      Pressing on with my Centaur build I am about to produce camshaft with timing gears and cams.
      I was considering securing the skew timing gears to their shafts with a grubscrew into a tapped hole in the bore/shaft joint – does that sound ok?
      When it comes to the cams on their shaft I would like to be able to have some sort of adjustment, the drawings show these as pinned and hence fixed.
      Shaft will be 3/8 in diameter and the Boss’s of the cams is drawn up as 3/4 in.
      Any ideas with regard to an ‘adjustable fixing’?
      Alan
      AJW
        @ajw
        #381436
        Jon Lawes
          @jonlawes51698
          What about a vernier gear? different number of holes in two halves of the same gear, one indexed to the shaft and the other with the lobes on? or something of that ilk.
          #381437
            I'd stick a grub screw in the boss so you have some adjustment and then when you have it running right change for a pin of put a flat on the shaft and keep the grub screw
            #381439
            MichaelR
              @michaelr
              On my Centaur I used grub screws for the skew gears (not tapped into shaft) and the same for the cams, they have not moved at all during running.
              Mike.
              #381443
              geoff walker 1
                @geoffwalker1
                http://www.plans-for-everything.com/hen_steam_engine_plans.html
                Hi Alan,
                Have a look at the above website.
                Scroll down until you see the JEPSON engine.
                Download the drawings and have a look at the adjustable cam design.
                It is a simple "pinch" clamp, very effective, Takes a little time to make but much better than a grub screw.
                Geoff
                #381471
                AJW
                  @ajw
                  Thanks guys, I like the idea of the Nelson eccentric clamp but don’t want it to get too bulky and obtrusive.
                  Depending on how much space is available I could consider a tapered collet type setup although as Jason says, once it’s setup it will stay setup so the simple grubscrew changed for a pin later sounds the simplist.
                  What do you think about the ‘end on’ grubscrew in the gears/shafts as any adjustments would be made at the cam end?
                  Alan
                  #381478
                    If you do it at the gear end then you will only be able to adjust the cams as a pair not individually. Key the gears or at least have them solidly fixed.
                    Edited By JasonB on 20/11/2018 07:20:42
                    #381497
                    AJW
                      @ajw
                      What I meant was! Fixing the gears to their shafts (not adjustable) then, as the cams are independent of each other, making any timing adjustments at that end.
                      Alan
                    Home Forums I/C Engines Topics
