Valve timing.
Valve timing.
Home Forums Locomotives Valve timing.
  • #619668
    Michael Callaghan
      @michaelcallaghan68621
      Hi, can anyone please explain to me the method of setting valve timing by blowing into the locomotives cylinders please. Thanks
      Michael Callaghan
        #619766
        bernard towers
          @bernardtowers37738
          I had a friend who did his timing by using jars filled with water and tubes from the exhaust into these jars thereby pinpointing the exact time the exhaust opened.
          #619771
          Michael Callaghan
            Thanks. That’s the sort of information I was looking for.
            #619772
            Jon Lawes
              @jonlawes51698
              Following a recent thread on the subject on a different site I think you can get a better feel by attaching a tube to the drain cocks and gently sucking.
              #619777
              Michael Callaghan
                Now that’s a good idea thanks jon
                #619821
                bernard towers
                  @bernardtowers37738
                  I think the bubbles in the jar of water is more accurate.
                  #619874
                  Paul Lousick
                    @paullousick59116
                    Timing should be done when the engine is hot and parts have expanded. (And I would not recommend sucking, especially on a large/full size engine with steam and oil)
                    #619875
                      Posted by bernard towers on 04/11/2022 18:17:49:
                      If the exhaust opens before the inlet due to lap how does blowing show when the exhaust is open? Unless you are blowing into th edrains and not the inlet.
                      If you suck from a drain cock you will draw in air through the exhaust regardless of whether the inlet is open or not.
                      Like wise sucking on the drain cock with eh exhaust blanked off will indicate when the inlet opens.
                      If you want to use water in jars and avoid sucking in something nasty have a sealed jar with two connections – one for a pipe to go into the water and another above the water to suck.
                      I also doubt that any blowing into the cylinders via drain cocks would work, at least not on a slide valve setup as the valve would just lift, may be OK on piston valves.
                      Edited By JasonB on 06/11/2022 07:32:31
                      Edited By JasonB on 06/11/2022 07:46:55
                    Home Forums Locomotives Topics
