valve size
valve size
Home Forums I/C Engines valve size
  • #185933
    Farmer Dave
      @farmerdave
      Hello all Can anyone help. I have built a 2 cyl boxer horizontal 4 stroke with atmospheric intake valve and mechanical exhaust, I cant get it to run very well,I suspect the valves and air ways are to small for the size of the cylinders (28mm bore x 30mm stroke) the valves are only 8mm dia what would be the optimum size for the valves. Thank you all in advance Dave
      Farmer Dave
        @farmerdave
        #186002
        Ian S C
          @iansc
          Dave, have you tried lighter springs on the intake valves.
          Ian S C
          #186010
            Nearest I've done would be the IHC that had 1" borex 1.5" stroke, valves had 0.328" heads on 3/32" shafts ports were 0.312"
            I also have a hired man 1.25" bore x 1.625" stroke that has 1/2" valve heads, 1/8" stems, ports 0.339"
            As Ian says a very light spring on the inlet valves, if you have compression you should be able to hear the valves sucking in air and see movement, like this
            #186061
            Farmer Dave
              @farmerdave
              Thank you for your suggestions guys. Intake valves are bobbing up and down nicely, the springs are very soft, I don't think that is the problem.Jason the engines you use as a comparison would confirm my valves are to small and I've started to make larger ones and I think I'll raise the compression a little.
              Regards Farmer Dave
              Edited By Farmer Dave on 10/04/2015 21:35:59
            Home Forums I/C Engines Topics
