VACUUM GROOVES
VACUUM GROOVES
Home Forums Locomotives VACUUM GROOVES
  • #43459
    G.E.M.
      @g-e-m
      HAS ANYBODY ANY INFORMATION ON VACUUM GROOVES IN SMALL VALVE PISTONS.  RATHER THAN FIT O RINGS OR PACKING YARN. ie HOW THEY WORK AND WHAT SPEC, IS REQD.
        REGARDS GORDON MAY
      G.E.M.
        @g-e-m
        #43462
        Circlip
          @circlip
          First poin Gordon, KILL THE CAPS LOCK, it don’t arf stab you in the eyes.
            Trying to take an objective view of your question with ref. to the “O-Ring” and Packing yarn bit, the “Vacuum” grooves you are reffering to are actually Oil grooves.
            When turning a piston, the first two mentioned are recognised methods of obtaining a sliding seal between the piston and bore faces. Another is a metal piston ring.
           If you can obtain a “Ploppy” seal to the piston and bore (Essential on a Stirling or hot air engine) then if you turn a couple of grooves in the piston body, when the engine is running it allows an oil film to be dragged onto the bore walls which not only acts as a “Seal” but is pretty effective at lubricating it as well.
              Regards  Ian.
          Edited By Circlip on 11/09/2009 12:36:44
          #43471
          G.E.M.
            @g-e-m
            Thanks for the info, Ian all is now clear
              Regards Gordon.
          Home Forums Locomotives Topics
