V twin double acting oscillating engine.
Home Forums Model Boats V twin double acting oscillating engine.
Viewing 25 posts - 1 through 25 (of 31 total)
  • #197303
    Mark P.
      @markp
      Hello all, I am looking for a set of drawings/plans for a small V twin double acting oscillating launch engine. I have trawled the internet to no avail,I seem to have gone round in ever decreasing circles. Can anyone point me in the right direction please?
      Regards Mark P.
      Mark P.
        @markp
        #197305
        Bazyle
          @bazyle
          There is probably a Malcolm Beak design on Paddleducks otherwise if no responses here ask on Modelboatmayhem.
          #197314
          Thor 🇳🇴
            @thor
            Hi Mark,
            The Model Engineer magazine (Jan. 2003 to Nov 2003 IIRC)ran a series of articles by Colin Pape on oscillating steam engines. One of his engines was a twin V double-acting.
            You can just enter the authors name here and search for the relevant issues.
            Thor
            Edited By Thor on 20/07/2015 05:36:05
            #197324
            Old School
              @oldschool
              Reeves do a V twin double acting engine, unfortunately it does not always self start in forward and reverse the V is not wide enough. Mine powers a small radio controlled Victorian steam launch.
              #197328
              David Clark 13
                @davidclark13
                Lots of designs on the internet. Try john-Tom.com
                #197347
                Mark P.
                  @markp
                  Thank you for the replies, I tried John-Tom David but there was nothing suitable there. Is there anywhere where I can buy plans from have tried myhobby store.
                  Regards Mark P.
                  #197349
                  Graham A 1
                    @grahama1
                    I have the Stuart Models stationary steam engine, twin oscillator plans,they relate to the castings kit and were bought from them when they were on Guernsey.
                    #197350
                    Gas_mantle.
                      @gas_mantle
                      Why not just take the design of an existing double acting single and modify it into a twin version ?
                      #197352
                      Ian Hewson
                        @ianhewson99641
                        Blackgates do a vee twin reversible engine.
                        #197356
                        Mark P.
                          @markp
                          Hello, I have thought about that Peter and that is one option.but I would like to build a tried and tested one. I don’t want to buy a kit as I wish to build from scratch.
                          Regards Mark P.
                          #197360
                          Roger Holebrook
                            @rogerholebrook12949
                            Can I suggest the article "starting in steam" by Peter Arnot , in Model boats magazine commencing in June 1988. Just as a matter of interest, there is also a four cylinder version with both boiler and boat design.
                            I am building both the two and four cylinder versions myself.
                            Roger
                            #197372
                              Couple here but not sure if they are double or single acting, first one could be as it says "duplextype"
                              Here and here
                              #197384
                              john carruthers
                                @johncarruthers46255
                                What about Brunnel's 'Double Diagonal' drawings (£23).
                                Gas_mantle.
                                  @gas_mantle
                                  John,
                                  That's a useful link I haven't come across whilst looking for something to have a bash at, I'm tempted by those drawings myself but try and simplify it a bit to suit my own skill level.
                                  Has any one built that model and able to comment on it's suitability for a beginner ?
                                  #197391
                                    Peter, Mogens Kilde did a simplified version of a double diagonal from barstock that started in ME 4383 that would be an easier build
                                    Edited By JasonB on 20/07/2015 15:58:12
                                    #197412
                                      Truckloads here if you don't mind using castings:
                                      http://www.ajreeves.com/popular-311-c.asp
                                        Truck loads? only one is a double Vee which teh OP wanted and I have a feeling they are single acting
                                        #197415
                                          They can all be made as single or double acting, I presume that the 'vee' requirement isn't absolute, as long as it's self-starting.
                                          John Rudd
                                            @johnrudd16576
                                            I can confirm the Reeves Pop is a DA steam engine….
                                            I have one and the plans ……just need to build it…
                                            Edited By John Rudd on 20/07/2015 19:35:18
                                            #197428
                                            John Rudd
                                              @johnrudd16576
                                              I should add that the engine can be built single or double acting….
                                              #197434
                                              steamdave
                                                @steamdave
                                                Does it have to be a Vee configuration? If not, here's one for you:
                                                http://www.vapeuretmodelesavapeur.com/telechargements4/twin-vose-slim-ok-d-j-publi-.pdf
                                                The Emerald isle
                                                #197450
                                                Mark P.
                                                  @markp
                                                  Thank you for your replies I have been in touch with Reeves about a set of drawings.
                                                  Regards Mark P.
                                                  #515317
                                                  Tony Wright 1
                                                    @tonywright1
                                                    Hello I wrote an article for model engineer v twin steam plant . Can’t remember the issue number . A couple of photos for you .A wright
                                                    #515325
                                                    Nathan Sharpe
                                                      @nathansharpe19746
                                                      Jason B,
                                                      Didn't Tel do a write up on MEM? Or am I mixing it up with another type of engine?
                                                      Nathan.
                                                    Home Forums Model Boats Topics
