UV Cure Resin
UV Cure Resin
Home Forums Materials UV Cure Resin
  • #443157
      When I ran out of 'Lazer Bond' I ordered a cheap look-alike of eBay because I couldn't find it in the Range any more.
      I used the cheap version earlier today. It took ages to cure, despite the UV LED looking just as powerful (LB was almost instantaneous). One joint is rubbery (probably not fully cured), another one was brittle.
      So, these are definitely not all created equal, and I stand by my positive mini-review of Lazer Bond and now am looking out for a new source of it!
        Nick M0NPH
          @nickm0nph
          Hi Neil
          have a look at fly fishing equipment i am sure that they use uv cure resin for fly tying
          Nick
          #443172
          Enough!
            @enough
            Since "genuine" Lazer Bond and its imitators all seem to be called "Lazer Bond" how do you tell the difference?
            #443183
              Posted by Bandersnatch on 24/12/2019 18:38:10:
              Not easy!
              This is the 'official packaging', but ones with similar looking dispensers may or may not work well..
              #443185
                Interesting..being sold on Amazon with that picture but 'without box' in the details.
                I suspect 'Lazer Bond' is no longer distributed by JML, but the product is still being sold in the USA (nearly £30 before import taxes!)
                The 'fakers' may or may not be the same but of course no guarantees on the composition/quality…
                  I suppose the obvious [but not inexpensive] answer would be to purchase direct from JML
                  … when/if it is stocked again.
                  https://www.jmldirect.com/catalog/product/view/id/4087
                  Edited By Michael Gilligan on 24/12/2019 19:30:56
                  #443205
                  Jeff Dayman
                    @jeffdayman43397
                    Hi Neil, as mentioned on another thread I have had success with Dymax UV cure adhesives but they are very expensive industrial quality stuff. If you talk to your dentist he may tell you where he buys his, as used for non metallic fillings in teeth. Very good stuff if you can get it.
                    The distributor I use for Dymax products is adamant that success is only guaranteed if you use their UV cure lights – they say the frequency and intensity are critical to good cure. They also say that the Dymax products have short shelf life, and after the expiry date on the cans they must not be used for anything critical as they may not bond well.
                    I have had iffy results from the hardware store stuff. Could be the LED in the pen not being just right, could be shelf life issues. It is not cheap in hardware stores here. I paid $14.99 (about 10 UK pounds I think) for a 15 mL pen last time I bought some to experiment with. Have not bought it since.
                    #443222
                    Enough!
                      @enough
                      Posted by Neil Wyatt on 24/12/2019 19:20:58:
                      Some of the eBay ads seem to do the same thing. While not stating "without box", if you read between the lines ….
                      #443226
                      Danny M2Z
                        @dannym2z
                        Posted by Nick M0NPH on 24/12/2019 18:28:19:
                        Hi Neil
                        Nick
                        This is what I use for finishing some fly heads. Many grades available for various uses. LOON UV cure resin
                        For cheaper stuff search for surfboard repair UV cure.
                        * Danny M *
                        #451056
                        Bo’sun
                          @bosun58570
                          I keep getting an ad via You Tube for a product called "Bondic". Developed by a UK dentist apparently. Sounds like the same sort of stuff. As always, the claims for these things are very impressive, but it could be worth a punt in lieu of anything else.
                          #451059
                            You can't really tell from the picture. A valid reason for importing 'without box' is to reduce shipping costs. The photo is of clunky DIY store type consumer packaging, more presentational than efficient and unlikely to be how LazerBond is packaged for industry and sold in bulk at much lower cost.
                            Or maybe it's a dodgy imitation. Only way to find out is to buy some.
                            #451099
                            Enough!
                              @enough
                              Posted by SillyOldDuffer on 07/02/2020 13:50:25:
                              I did, if it ever arrives ….. without chicken goop.
                              #451108
                              Jim Wills 6
                                @jimwills6
                                Just purchased a quantity of Bondic, having read about it for the first time, looks like just the thing for rebuilding broken tabs on my motorcycle plastic covering items. Now I see it comes from the states so expect import charges on top of £60.19 purchase price.
                                Jim
                                Edited By Jim Wills 6 on 07/02/2020 17:10:49
                                #451112
                                not done it yet
                                  @notdoneityet
                                  If you want a large bottle of the stuff, look no further than 3 D printing supplies?
                                  #451799
                                  Enough!
                                    @enough
                                    Posted by Bandersnatch on 07/02/2020 16:07:46:
                                    Mine arrived today. It looks exactly like the picture that Neil posted above and says "Adhesive Made in USA" It also carries the obligatory California Health Warning.
                                    It was shipped in a padded envelope and the red compartment at the bottom had, apparently, taken a hit and was crushed. The corner of the package had also become unsealed in that area. (There were signs on the padded envelope that it might have taken a (very local) hit from a sharp corner).
                                    The tool was leaking. That didn't appear to be related to the aforementioned package damage. Unless I can easily do something about it, I'll probably just dump the whole kit & caboodle – leaking smelly/toxic chemicals are more trouble than they're worth. My fingers stink as it is.
                                    The red compartment was empty. Is it supposed to be?
                                    #451800
                                    Steviegtr
                                      @steviegtr
                                      JB weld seems to out perform all of them. look it it up on youtube.
                                      Steve.
                                      #451806
                                      Pero
                                        @pero
                                        Except that JB Weld is a two part epoxy not a UV curing adhesive. It is also very opaque, not transparent which may be a consideration.
                                        Another possible source is the adhesive used for attaching rear vision mirrors to the inside of car windscreens. Widely available from car parts and hardware stores and obviously very durable as it has to withstand extremes of temperature ( and humidity ) as well as bumps and mirror adjustments. It comes in small quantities but is relatively expensive.
                                        Pero
                                        #451870
                                          I’ve just been treated to a Youtube advert for Bondic **LINK**
                                          https://notaglue.com
                                          … May be of interest.
                                        Home Forums Materials Topics
